Powder coating fuel tank?
(In Topic #104385)
Question is, as there is a large hole in the tank where the fuel sender/lift pump slots in, what will happen if any powder coat gets inside the tank?
You think it will be alright or should I try to plug the hole as best as possible before having it coated?
If you're still worried then Frosts do a tank repair formula that seals the inside of the tank. Try www.frost.co.uk.
Tim.
I'm not sure what petrol would do to the powder coat, but it may well dissolve it over time (not 100% sure - but I wouldn't risk it).
HTH
Rich
i powder coated a mini subframe once,as soon as the paint got chipped the frame started to rust.would not powder coat again under the car best to paint then waxoil underneath
paul
Life Member
