Pierberg 2E carb->manifold attachment
(In Topic #96445)
I have a 1991 Clipper Cabriolet which isn't running right - on examination, the carbs aren't attached to the manifold any more - the rubber has totally perished! The Haynes Book Of Lies is about as much use as usual, I can't figure out if the rubber is replacable or not? It looks like it's somehow rivited to the carb body. Oh, edited to add: It's a Pierberg.
(Tempted to just get a reconned one from e-bay, but ?135 is more than I'd like to pay - the hood isn't in a brilliant state anyway and I'm not 100% certain that's the only trouble with it, but the main problem with the whole car just seems to be the state of the carb)
1983 1100 C
1983 1100 C
I would stick with trying to sort yours first though. While you're at it worth replacing all the vacuum hoses on it. They often split, turn porous or perish with age and the vacuum system on the 2E2 is quite critical. You can get a couple of metres for a ?5 from a motor factor.
1983 1100 C
1983 1100 C
to replace it when you take carb off should be two nuts holding the flange to base of carb off new one on jobs a goodin
dunno if i just wasted my time and you've already fixed it? but it's nice to feel clever lol.
rustys_mk1 said
did you replace the flange at the base of the carb?
Yup! Trouble is, I think it's been bust for a while and most of the connections into the carb are shot where it's been rattling round loose. The clouds of smoke from the engine when I start her up is coolant that's spilt on top of the engine because one of the connections into the waxstat has broken off. Looks like at least one bust vacuum connection though means she won't even run without my foot half way to the floor on the accelerator, so I'll need to recheck the connections. (I did have a Pierburg workshop manual in PDF format somewhere, it's much better than the Haynes book which isn't very clear on the vacuum connections at all)
http://vwa1.dadoghouse.com/wp-content/uploads/2006/02/2E2%20service%20instruction.pdf
1983 1100 C
1983 1100 C
markwon said
Not sure if you mean this one, but is a good 2E2 manual…
Its good enough for me to use
Thanks a lot M8.
