Only takes a tenner to fill my tank?!
(In Topic #145875)
Jamie
what exactly is the problem here, are you sure the tank is ever actually empty before you try to put £10 in? maybe the level sender is reading wrong,it sounds to me like you're just keeping the tank almost full to the top all the time
is it a gti or carby actually, also what year
Re: Only takes a tenner to fill my tank?!
CarnieMK1 said
? I thought maybe this was an issue with the breathers as 1 currently only have 1 outlet connected, the main one to the filler neck. The others still have the rubber caps.
This bit troubles me. Did you fit a new tank, and not connect everything up as on the old tank? This could explain fuel starvation due to no breather on the tank, which might be being perceived as no fuel (empty tank) when it runs out.
