Ongoing fuel system issues
(In Topic #110684)
Ongoing fuel issues with my '83 gti. Managed to get her started over the weekend a few times, but each time it would cut out after about 10secs.
It struggles to start for a few secs beforehand, but then revs fine etc. until completely cutting out again.
Had one minor issue where a fuel line came loose and sprayed petrol all over the drive, that was easily resolved so i assumed the pump was ok
Had a look at the filter and all seems alright there too, no crud, and petrol seems to be reaching it fine.
Before it started having this problem i had the lines, pump and filter replaced. It had a new filler neck before i bought it, but don't think the tank was changed.
What would be the next step / area to check, injectors?
Any ideas or suggestions would be much appreciated.
Thanks,
Dan
If I didn't have this, then I'd do a basic check that the metering head flap can move, is centralised and correctly adjusted within the conical tube (flap just below start of angled sides).
