no fuel to injectors
(In Topic #140318)
The main fault is that there is fuel to the metering head with good pressure up to the cold start injector but not to the 4 main injectors!!
Is the metering head doneor can I fix it or is it another fault I dont know of??
Sorry for hijacking your thread.
I will let you know if I get a cure
just fyi fuel wont get to the injectors unless you lift the metering head flap up
this was something i over looked when getting mine running i was that inpatient to get it running i didnt have the rohr pipe connected thinking it was only to the air filter but the flap doesn't lift without it hence no fuel …
