My fuel problems
(In Topic #81126)
My fuel problems
Next i had humming noise from the area of the pump which is under the car,that sits next to the petrol tank. After being ok for a few weeks, last week every now and then, there would be a loud buzzing noise coming from the area of this external pump. While i was in a traffic jam, this buzzing got louder and eventually,the car cut out. It wouldn't re start straight away, but did after resting a few minutes.
Over the next few days, the car would run fine if i was doing a decent speed, but as soon as i got in slow traffic, it would happen again.
then this week, the buzzing was there when first starting the car. My car,which is 92 GTI, is now in garage, having had this external fuel pump replaced, except that its not fixed the problem. In fact is running worse,coughing and spluttering and wont go over 3000 revs.
ANY IDEAS?? Checked older posts but although similar probs none exactly like this. Thank you for your time.
Luvbugz
Slightly different on a cab, but my Tin Top pump has a removable thimble shaped filter gauze on the inlet side which was catching crud from the tank, but restricting supply to the pump…
My Build Thread
Also, does anyone know who,in the Northamptonshire area, has the capability to do a pressure test, as my mechanic hasn't the equipment.
Thanx
Luvbugz
