MKII fuel pump
(In Topic #111122)
MKII fuel pump
It has been suggested that I can get the said parts off a MKII, can anyone confirm or deny?
The accumulator will work though, its the same as early MK1 item at least. The later cab/rocco accumulator might be a bit smaller, looks that way from what few pics I've seen? But again if you can fit it in under there then it'll work.
edit: you may have to use the mk2 lines as well, not 100% sure if the MK1 lines will bolt to a MK2 pump. Problem is the lines may not be long enough to reach over to the passenger side like they do on a MK1…
