MK1 GOLF running polo gt engine, running issues!!!
(In Topic #139515)
the issue i am having is it practically stalls when cornering, feels just like running out of fuel but then bursts back to life one back on the straight, i didn't carry out the conversion myself nor the previous owner. my thoughts are that the problem lies with in the fueling it has a electric fuel pump fitted next to the tank.
But i am not sure what the fueling setup should be on this conversion my thoughts are to replace the pump all lines and filter (the ones linked below) let me know what you guys think or any advise would be appreciated.
http://www.ebay.co.uk/itm/3M-x-8mm-I-D-BRAIDED-PETROL-DIESEL-FUEL-LINE-HOSE-PIPE-/250508869922?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a537e0122#ht_2460wt_1008
http://www.ebay.co.uk/itm/370522802769?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Regards
Ive Drove Many Cars, But NONE Like A MK1
either that or fit a mk1 tintop gti fuel tank with the internal swirl pot and outlet on the bottom
recomended best place to pick these up? best to buy new you recon?
thanks again!
http://www.ebay.co.uk/itm/230725501850?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/200691149226?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
regards
oh and the main pump you have already will probably be fine to keep, you just need the lift pump + swirl pot to keep it supplied with fuel to stop the fuel starvation on cornering.
the other solution is a tintop gti fuel tank with built in swirl pot, basically use whatever comes up first
