MK1 Cab 1.8i Intermittent Misfire
(In Topic #135714)
I have a bit of a problem which has just started. Car starts fine, then misfires for about 5 mins, then clears.
I have changed the spark plugs, rotor arm and cap.
Has anyone else experienced this and found a cure? I've never had any other problems with the car whatsoever.
Cheers,
However, on top of the throttle housing there is a black microswitch thingy with two wires going to it. if i press that the pump (i think its a pump) on the side of the airbox starts to work and cures the misfire. I need a solution to fix it without keeping the switch closed.
can you try to get a better pic of it so we can figure out what it is?
So, if the throttle switch is open the k-star injector stops working, close it and hey presto it works and it runs fine.
There must be something else in the equation which also makes this injector work, so i need to find out what that is i guess.
I really do appreciate your help with this bud.
trouble is not many people can tune it now! if it is the k-star + fuel though its worth good money to the right people. you could return your car to standard and retune the idle/co/timing to suit super unleaded.
if it was me, id start by checking carefully for vacuum leaks, then move on to checking idle, co and ign timing to make sure all is well. then if still not right pull the injectors and do a flow/spray pattern test, plenty of info on that on here
If you or anyone does know a good tuner not too far from Leicestershire then please let me know.
Cheers,
