Kangaroo fuel
(In Topic #116059)
Kangaroo fuel
mark
:dontknow:
If you have a compressor blow through lines but make sure both ends are removed from everything
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
1988 1.8 carb Golf Clipper
brucieboy said
i have the same issues!!! i have checked the fuel tank, it looks clean, but unlike the pics of the fuel tanks ive seen i dont have a filter type thing visible when you look in, i have replaced the fuel filter, more investigation is needed!! grrrrrr i think ill fill it up full and see if that makes a difference.
Dpends on model whats in the tank, myns a 1.8 carb 1988 and so doesnt have a filter per say just a tube with strainer holes at the bottom. If its had fuel supply issues before someone may have got rid of the strainer. If you post model and year I am sure someone will know what that sender unit should have, perhaps even a pic..
ahh yeah mine is a 1.8 carb '90 and it has one of this tube things, looks like a wire tube as such.
so is that the filter in ours? should i take that out and clean it out?
