K-Jet Fuel Delivery
(In Topic #158737)
Website Manager
The metering head has a pressure regulator in it, essentially a restriction, which causes pressure to build up as long as the pump has enough umph to flow the fuel.
So your findings are spot on, with the restriction (pressure regulator) the pump has to work harder hence the increased current consumption.
You really need to get a pressure gauge to measure the system (and control) pressures to see if the pump is managing to get up to the correct pressure.
I would still say your pump is on the way out though.
Is this a cabby or tin top ?
If it is a later cabby, post 84 I think, then there will also be a second pump in the tank called a lift pump - this pump may of failed or failing.
It is an '86 cabby and does indeed have a lift pump, I checked the pump and its strainer ages ago but not while doing the delivery tests. Does anybody know what delivery to expect from the lift pump when testing separately? I'm currently sourcing bits to make a pressure tester so hopefully that may shine a bit more light on it. I've read about mesh strainers on the inlet of the pump, would mine have this as it has a lift pump in the tank with a strainer attached?
Website Manager
They are only fitted because VW consolidated to one common tank for carb and injection.
If the lift pump has been failing then you need to check the fuse box and the fuel pump relay, because as you found as the main pump fails to deliver it draws greater and greater current trying to do so, sometimes it is enough to melt the solder on the relay. I have seen it where this eventually caused the fuse board pins to corrode away.
Website Manager
Website Manager
System pressure with engine running and test valve closed = 5.3Bar
Cold pressure with AAV & WUR unplugged with test valve open = 1.3 Bar
Warm pressure with engine up to temp and AAV & WUR plugged back in with test valve open = 3.5 Bar
After the test I left the test rig connected, pressure was 2.9 Bar and didn't drop in 20mins.
I thought I'd test the lift pump flow so disconnected it and ran it in a jug, it produced approx 1000ml in 30secs, when I closed the valve to test the pressure it would produce I noticed it was spraying from the pump, I thought it might be leaking from the short piece of hose on the pump but it turns out there's a tiny hole in the top of the lift pump (see photo). Does anybody know if this is supposed to be there, I assume it is to relieve the air out of it??
The bently manual says the lift pump should deliver 300ml in 10 seconds - so seems good. I would bet the hole in the lift pump is a pressure release as the pump is not designed to create high pressure.
gav
