interchangable injectors
Hi
Just a quick question.
Just wondered if injectors are interchangable between years.
I've got an 83, 1.8 DX engined Golf, and i got hold of some later, injectors.
They look exactly the same.  The treads are the same size, and they don't have the top hat bit on them.  The only difference is the part numbers (which i don't have to hand, but can look at if required).
Just want to know if they're interchangeable.
Do they have different spray patterns or work at different pressures etc.
I know there've been posts on a similar subject, but i couldn't find any that directly relate to this.
Hope someone can help
Tom
Check these from Ebay
Tom
First add is later Top hat version MK2 type
Second is earlier version with out top hat
See also http://www.vwgolfmk1.co.uk/Main/Testinjectors.pdf
[ Top marks to Prowler ]
Both fit and do the same job ……..I don't no the difference  :dontknow:
http://cgi.ebay.com/Volkswagen-VW-Golf-GTi-8v-Injectors_W0QQitemZ4621938520QQcategoryZ9889QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/81-82-83-84-VW-Scirrocco-Jetta-Rabbit-Fuel-Injectors_W0QQcmdZViewItemQQcategoryZ33554QQitemZ8050412652QQrdZ1
