How difficult is it to replace a fuel tank ???
(In Topic #124196)
Can anyone help/ anyone done this before?????
Pixie xxxx
The fuel filler is prob the source of the rust, that will need replacing. Some then get inside the tank via the inspection plate/fuel sender under rear seat and suck out any rust/debris/water in the tank.
If you are removing the tank the exhaust, hand brake cables and brake pipes need to come off and are often rusted solid and end up needing to be replaced.
You need to lift rear of car. Be very careful of shearing the 4 studs that hold the axle to the car, wire brush, run old nut down with a slot cut in it, spray with relase fluid, wire brush until shiney, spray with oil. I think in past I've left the lower shock bolts in and there is enough room to slide tank out.
Gonna have a stab at it tomorrow after i finish work
Wish me luck :wink:
