help needed with starting
(In Topic #106525)
As you say it could be the fuel accumulator that has got rust from the tank in it this would cause both hot and cold start problems, but if it runs ok after a while its unlikely to be this.
More likely its a problem with plugs or distributor, also could be timing is out so check that 1st and see how you go on.
Plugs you can check by removing a lead one at a time(turn engine off in-between) and see if the noise changes or even if it wont start at all.
Unlikely to be fuel pump I would've thought as they either work or don't work
~Madferret
Mk1 1457cc 5door GX '83
