help how to get sender unit out of tank
(In Topic #99385)
There's a rubber o-ring between the sender plate and the tank which can perish over time, so you may need to replace it.
HTH
Rich
I dreamt up a great way of doing it easily.
See here…
http://www.vwgolfmk1.o…ms&file=viewtopic&t=43121
Chriselias272 said
With respect - DON'T HIT IT WITH CHISELS OR A DRIFT. I found out that this is a really good way of snapping them.
See here…
x2
I've jammed different tools in, probably not such a good fit as the 3/8 ratchet and ext bar, but with more or less the same effect. Just be grateful its summertime - in wintertime when its cold, that particular type of plastic is very brittle and easily snaps even with the most careful attempt to remove!
The method with the ratchet and extension bar looks really neat…
Rich
Life Member
