HELP fuel tank pressurising BIG TIME!!!
(In Topic #79397)
Just wondering if anyone could shed any light on this VERY annoying problem.
Basically my fuel tank is buiding up a massive amount of pressure, even on reletavly short trips.
When I remove the filler cap after every trip (which I have to do now) it is almost blown clean out of my hand as the pressure build up is that bad.
I have blown out all breather pipes, changed the filler cap three times, changed the fuel filter and also changed the gravity valve which fits in one of the breather pipes.
I even drilled a hole in the top of one of my spare filler caps, obviously this stopped the build up of pressure but the fumes were making their way back into the car which isn't that nice after a while, and i like the smell of petrol.
Apart from this the car runs spot on. :dontknow:
Any feed back regarding this would be greatly received.
Many thanks, allsorts.
Mk1 Golf GTI 83 Y reg in Lhasa green
Rear disc conversion
Lowered 20mm
14" Campaign Pirrelli P Slots
Lowered 20mm
I know there is supposed to be some pressure, but I've owned nothing but VW's for the past 15 years and never have I had anything like this, it realy has to be seen and heard to be appriciated.
Lowered 20mm
Lowered 20mm
I still think you are looking at a breather problem in the tank area . Have you been under the car and checked the breather that hangs near the back of the spare wheel well ? This can get blocked with road much . Also remove the gravity valve and blow down both lines that connect to it .
I remember this happening to someone a few years ago when this site was the 'Campaign Register' and it turned out to be a bloked pipe from the tank . Also if the gravity valve is not in the upright position all sorts of strange thinks happen .
Thanks Chudd…….
I realy thought i'd cracked it before putting the gravity valve on as when you blow in the new valve, air flowed freely one way, but I realy had to blow very hard the other way, like blowing up those silly long baloons.
Where as the old one wasn't allowing me to blow through it at all in the direction from the tank. 'BINGO' I thought, but no.
Am going to have another look at it this weekend, if it stays fine!
Thanks for the replies though. I'll keep you posted. :?
Lowered 20mm
Lowered 20mm
its got me stumped. all breathers and gravity valve replaced, but to no avail.
are there any other pressure regulating valves?
allsorts said
The pressure build up is so great its forcing fuel to leak from the filler pipe at the last jubilee clip before it enters the tank.
I have exactly the same problem on my Campaign, fuel is getting past the jubilee clip and dripping onto the floor. :x This problem has only come to my attention in the recent warm weather. Taking the fuel cap off results in quite a rush of air etc.
Would be interested in any comments as to how to help resolve this. Have looked at all the suggestions above but to no avail.
Result:
Pin hole corrosion on fuel tank (near jubilee clip) to blame. New fuel tank fitted. :roll:
just wondering if this is due to the exeptionaly hot weather or is there a filter in the breather system that could be blocked?
is the car ok to drive for the time being?
1983 lhasa green GTI
1982 lemon yellow CL
Don't worry, can't be far from ironing your fuelling problems :borg:
1983 1100 C
1983 1100 C
time to source a good 2nd hand VAG one then
still,at least it runs
tanks for the help markone(tanks, geddit!!! sorry)
So does all this mean GSF tanks aren't worth fitting or is there a way round this :dontknow: .
1983 1100 C
1983 1100 C
undoing the filler cap very slowly to release the pressure works.just glad the cars running!!
think il get a genuine tank and fit it over the winter
