Going to change the vapour seperator...straightforward replacement?
(In Topic #152340)
Hello
My stalling saga continues, changed/have done the following but still no joy so onto the vapour seperator:
-changed plugs, ht and dizzy cap
-new pump
-cleaned majority of rust in tank (continuing weekly), changing filter when filled…getting better..
-cleaned carb
Can anyone give any pointers on how easy to change the vapour seperator- is it a simple sway in type job?
Ross
-new pump
-cleaned carb
Ross
jellybelly said
Bolt off, bolt on attach the pipes
As simple as that mate
Awesome- cheers mate…lets hope it helps!
I changed mine and bought a cr
P
one from gsf. Ended up replacing that too. Get the best you can
vwbug said
I changed mine and bought a cr P one from gsf. Ended up replacing that too. Get the best you can
VW heritage one should be with me in the next day or 2…heres hoping its ok
