going from carb to injection- fuel tanks.
ALright guys, im half way through a Gti swap into my mk1 that was originally a 1.6 auto.
i have a mk1 cabby for parts, which is a later model , so i understand the tank itself wont physically fit the car, but….
can i take the pumps and gubbins from the GTI cabrio tank, and run them on my original carb tank?
also, what are the differences between carb and injection tanks?
thanks for any help, Oli
I believe the GTi tank has a return for the fuel - a carb tank doesn't have a return.
I stand to be corrected though!
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
i dont know the answer to the question but i know my 1.1 carb has a supply and return to the tank!
i'm in the middle of doing the same thing myself, i'm fitting polo gt into a 1.1c. the carb tank indeed does have a supply and return going into the top of the tank, however the gti tank has a pipe coming out of the bottom of the tank to suppy the high pressure pump constantly with petrol. also the fuel line on the car are not a large enough bore.
i'm working on another option, it may, and i stress may be possible to fit a lift pump into the carb tank, i've picked up a polo item, and hook that up to the high pressure pump, again this is the standard setup on a polo. this would save changing the tank. however there will be no baffling in the bottom of the tank so fuel surge may be a problem.
best, neatest, and reliable option would be to fit gti tank pump and pipework.
Rusty Hookers Dub Club
Thanks Dan - That makes sense!
I stand corrected in my new orthopedic shoes!
1990 MX5 Mazda
well, incase anyone does a search trying to find the same thing out….
the cabby tank was a direct swap as it was the earlier smaller size.
the only difference i could see between the carb and injection tanks were that the carb tank had an extra exit (very small) that could have been blanked- but as they were the same fitment i chose to simply use the entire GI cab tank and pump set up.
 :D
