fuel tank
(In Topic #98281)
fuel tank
paul_c said
what year? There's a difference across the years too
the carbed engine is a w reg the gti injection is a b reg
basically what im doin is swapping engines fron the gti to the carbed 1 if that makes senese lol
Hope that makes sense
paul_c said
What chassis number's the B reg, because its kinda around the crossover time. Basically, the 'later' fuel tank was the same for FI and carb, but it was different to the earlier (which were different for FI and carb, but the same as hatchback (and Scirocco Mk1))
cheers m8 is there any way to find out for sure i just dont really want to have to change tanks if i can get away with just putting the pump inline
thanks for ur help so far m8
the carb 1 is wvwzzz157bk017628
cheers in advance
lee
i havent got a clue m8 thats y im askin lol its all ne to me is there a pump in the tank as well then ??paul_c said
Can't you simply put the lift pump into your existing tank, and then an external pump too like the later cabbys have?
lee20vt said
i have 1 out of a b reg cab m which is the gti i did post chassis number for them both if that helps im so lost with all this wish i had just put another carb lump init lol
This might sound really obvious, but look at the top of the tank, and:
1. check the size of the hole
2. Check the number of terminals on the connection (2 or 4?)
3. If 4, pull out the pump and try it in yours.
ok cheers fella i may have bitten more than i can chew with this 1 lol as im strippin the breg to make a gti out of a w reg which means the whole loom to not lookin forward to that bit lol
