Fuel tank replacement
(In Topic #98415)
I have purchased a new fuel tank for my 1988 Mk1 Golf Cabrio and want to know how easy it is to fit? I have replaced most parts on the car. Does anyone have a diagram or some instructions that I can read on this. very much apriciate some advice. Thanks
Its a little bit involved because the axle needs to come out the way.
Fuel tank
unless you
a) have a friend
b) are really strong
c) are good with spanners and seized bolts
d) can do brakes
e) risk needing to buy new rear shocks
f) have a nice tidy place off the road (ie garage etc)
i'd not start it.
but i've gone too far to turn back so will finish!!!
Chriselias272 said
i'm in the middle of doing it now.
unless you
a) have a friend
d) can do brakes
i'd not start it.
a) - axle can sit on a trolley jack, tank it light enough to lift/lower by one person
b) - so long as you use trolley jack, should be okay for the average person…
c) agree
d) agree
e) should be able to leave the shocks connected, just remove the axle front pivot bolts (see c though)
f) agree - need a bit of space to put stuff as it comes off, and get in/out from underneath car, etc.
