fuel pump/non return valve
(In Topic #82201)
It looks like there is nothing which is screwed into the old pump, which I can unscrew and transfer to the new. Can you buy a non-return valve, which might possibly screw into the new pump?
Time to look else where :dontknow: Follow basic checks remember the ignition :wink:
Keep us posted ……..
1983 1100 C
1983 1100 C
markwon said
What make is the new pump? I think Pierburg ones have a built in non-return valve and are slghty longer as a result?
I don't know, I'll have to look out the box or take it out of the carrier and have a look at it. The end (where the high pressure fuel fitting goes) was slightly different, but I couldn't see any extra parts attached. The new pump was thicker than the old one, too; the old one had an inner and outer rubber carrier, so I could use the outer carrier with the new one and not worry too much about the other one.
If the non return valve was faulty the car would stop instantly and not start again until the pressure in the system had been released. I had this problem and had to wait at least hour before she would start again. As Chudd suggested I would rule out the return valve as a problem.
Cussco
By sheer chance, another car of mine (non-VW) had a similar problem, where this valve was leaking and needed to be replaced!
1983 1100 C
1983 1100 C
markwon said
The Bosch pump will need a seperate screw-in valve 893 906 093 and a dome nut N 011 069 1, about ?22 from VW. Thinner Pierburg's have a have a built in one.
Nice one Mark, I'll sort out these items and fit them when I've next run down the remaining fuel in the tank. I might have a little experiment/look at the existing fitting I have, in case its this part and I'll save buying parts twice.
Thanks!
1983 1100 C
1983 1100 C
