Fuel pipe problem :(
(In Topic #130968)
you can buy repairs for them or copper pipe to replace them with
think crazyquiffs sell fuel pipes link on the the left<<
if you choice to make your own i can supplie you with the tools to make your own pipe. you just need to buy the pipe and the fittings of ebay s
hth
Re fuel pipe problem
Thanks for your help jellybelly!!I tried crazyquiffs and had no luck.basically I'm struggling lol.I've tried just about every vw dealer in the midlands and all they say is that they can't get them.do u reckon you could sort me out everything I need and I'll pay wat ever mate.let me know asap pleaseany thanks Kylejellybelly said
the other pipe if the fuel return
hth
If you just wanted to replace the rubber pipes then its the inner diameter which is important, as it will be fitting over a pipe or connection one end or the other.
I'll take a guess if you like but I wouldn't want to guess wrong and muddle you up, and I can't remember the sizes off the top of my head etc etc
Re: Fuel pipe problem :(
Milburn said
Hi all I got a query and I know I may sound stupid but there are two pipes,one fuel and I'm nt sure wat the other is running under the car?anyway I need to peplace them as 1 or maby both have split as they are rubber.basically everytime I turn the key petrol pisses out the pipe.does anyone know where I can get the pipes and wat sort of job am I dealing with?will appreciate ur feedback!thanks
I think you have attached the wrong pipe with your car's engine.
We provides protection against low water flow, lead leaching, corrosion and copper contamination.
