fuel leak
(In Topic #104331)
fuel leak
Chances are this could be from two areas;
1. Fuel pump
2. Fuel accumulator
Best thing to do is take a photo if you can. If it's the accumulator getting the pipes off can be tricky - with time they almost 'weld' themselves to the accumulator.
Don't panic though - take the photo and go from there. If it's leaking lots of petrol I'd be careful for obvious reasons!
Good luk
Check it's not just a pipe that's leaking - may not be as bad as you think. Good luck!
Best bet is get a photo up where the leak is - can advise then
