Fuel filler rubber hose
(In Topic #141301)
I need a new rubber pipe that goes between the fuel tank and the filler pipe but struggling to find one.
Anyone one know the best place to get one? Or easiest to just get some normal hose?
Get normal hose with same inside diameter and cut to suit, just make sure it's fuel resistant and shouldn't be a problem.
Try egay or the likes of pirtek etc.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
gsf do this, and the clips for it
I had a look on gsf website, couldn't find the hose on there, only the filler neck and tank.
Also couldn't find 16v scirocco handbrake cables on there which I need.
I'll have to give them a ring
Need a piece of this myself
Does anybody know the internal dia ? as I'd like to pick a piece up before I cut mine off.
bugger doesnt look like they do it anymore, or the cables.
fuel hose can get from VW:
n 901 196 01, 40x5x165 - 11.64
handbrake cable is NLA from vw but part number is 533609721, available from vw classic parts for £21 each:
http://vwheritage.com/vw_act_vwclassicparts.home_lang_EN_country_GB.htm
when i was doing research into other cables that might fit, the 88 on mk2 cables were slightly shorter, and mk4 or was it beetle? cables were a bit longer. not sure if the mk4 cables will fit the handbrake lever but i think they're similar lever to late mk2 and mk3. were some polo ones which may work too, give me a sec to recheck everything.
cables sorted by length, cant garauntee they'll all fit! not 100% on rocco cable length but I know it was somewhere between the mk2 post-88 and the polo ones:
1592 - 1H0 609 721 C - MK3 golf syncro
1600 - 191 609 721 H/K - mk2 golf syncro
1613 - 1H0 609 721 A - mk2 golf g60 & mk3 golf/corrado >94
1613 - 1H0 609 721 E - mk3 golf/corrado 94>
1625 - 191 609 721 F - mk2 golf >88
1630?- 533 609 721 - scirocco 16v
1645 - 6q0 609 721 F/G/K - polo 02-10
1670 - 1J0 609 721 L - mk4 golf/audi/leon/toledo a3 4motion/quattro
1698 - 1J0 609 721 AP/AQ - mk4 golf
1720 - 3A0 609 721 A/C - passat b4
1750 - 357 609 721 E - passat b3
1800 - 191 609 721 A - mk2 golf <88
I bought a length of hose (fuel resistant-Goodyear I think?) to do
Mine that fits well. It is a slightly smaller diameter but is a snug fit.
Pic of mine on the filler-
If anyone wants any bits cut for them drop me a pm and we can sort something out
1987 Caddy 1.6Turbo Diesel-GTD
Instagram: Cavscp
Instagram: Cavscp
Gsf still sell these hoses picked mine up today and fitted it 8O
GSF no 186VG0160
part no 29323
£9 50 + VAT
as RJ says 40mm int dia.
GSF no 186VG0160
part no 29323
£9 50 + VAT
proof of how crap their new website is then
Not as crap as the 2 clips I got from GSF they both snapped :roll:rubjonny said
But the rubber hose was fine
