Fuel filler neck for clipper Wanted advice
(In Topic #96052)
Desperately seeking sexy black pipe thingy as mines disintegrated from over use(kind of)!Or it may be the typical problem affecting mk1 cabs.Mines a one previous owner 55k Clipper mint really but has started spluttering and cutting out.Fuel filler rotting well so im thinking its replacement time.I thought ill start here and work my way through. ANY ideas on where i can get one as im reeeeaaally struggling
Hello, it's a standard issue with all Mk1s mate. I've just had mine replaced with a Cabby neck. You can fit a TinTop neck instead, they are much cheaper and only needs a basic mod to make it fit.
Do a search on here and you'll even find instructions to help you DIY.
Tian
Tian
IM probably being a nonce but i really wanted an original filler to suit without the mods....
jpii690 said
IM probably being a nonce but i really wanted an original filler to suit without the mods….
Well, just buy one mate. You can still get them very easily so go for it.
Tian :dontknow:
Welcome to the site…
I got a cabby filler neck from GSF last summer. Try website below to find a local shop.
Car Parts & Spares -- Buy Online with Fast UK Delivery | GSF Car Parts
Much more expensive than a tintop one as already ponted out.
1988 1.8 carb Golf Clipper
Life Member
you will pay more than double for the cabby filler neck than the tin top and what makes it worse is there is less pipe work in a cabby neck.
the mod is basically, take a hacksaw and cut a bit off if memory serves me right.
oh welcome to the site
Chances are you are paing the extra for some bloke in a factory somewhere to cut the end of a tin top one!!
