Erratic idling when hot
(In Topic #98826)
Cause Remedy
Leaks in air intake system (false air) Check air system for leaks
Sensor plate and/or plunger not moving freely Check for free movement
Cold start valve leaking Check cold start valve
"Warm" control pressure too high Test pressure
"Warm" control pressure too low Test pressure
Injector leaking, opening pressure low Check injectors on tester
Injected fuel quantities unequal Check for equal fuel quantities
Basic idle setting incorrect Check and adjust CO level
Copied from below , no definite answer but my favorite is air leak somewhere
Idle problem
