Dumping water from the cooling system
(In Topic #124564)
Also, look for orange/brown corosion around the engine which will point you in the direction of the problem. Check all hoses etc, back flush rad, change the stat.
Dumping water from cooling system
JSeaman said
It sounds like you already found the cause, you have a leak somewhere. I'd suggest parking on some cardboard and checking it periodically to determine the rough area and then track it back to source.
On second thoughts I'm not sure it could be a simple leak. All the fluid seems to be dumped in one go and it seems to be when the car has stopped - as at the MOT station.
Dumping Coolant
1. Go to your local auto factors and buy one (no more than a max of £20 though!)
2. Run the engine to normal operating temperature
3. Remove all 4 spark plugs
4. Get someone to hold the throttle open and crank the engine for 5-10 seconds
5. The compression tester will show a number which is the cylinder pressure in psi/bar, write this down
Once you've done all 4 cylinders post up the results and will tell you more
It's dead easy and I did a guide for mk3 supra if you're interested - check out www.mkiiisupra.net if that is any use to you
