Convertible fuel pump
(In Topic #163286)
Where are the fuel pumps for th Cabriolet version? Is one in the tank?
1985 Cabriolet GL
mark1gls said
One under the car in front of the drivers side wheel near the fuel tank and if you take out the back seat you will see a black round plate on the drivers side take the 3 screws out and you will see 2 fuel pipes and a electical connection, if you take the connector off and look at the plug if there is 3 connections there is a lift pump in the tank if only 2 connections then no lift pump.
Thanks.
Julesgreycab said
What year and model cabby you got?
Hi
1989
1.8 Gti
1985 Cabriolet GL
Julesgreycab said
Then as mark1gls has said
Thanks.
Have taken out the back seats but there is no inspection plate to be found. I cannot check the drivers side rear as my jack has just broken so will have to get that first.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=misc&id=your-mk1-golfs_2%2Fmy-black-sportline_3&start=60
