Clipper not running properly
(In Topic #137812)
i have an '88 clipper and i had problems with the carb so i bought a brand new webber due to the car cutting out and not being able to adjust the pierberg properly so i fitted the new webber and first time started perfectly and the car sounded as sweet as a nut. but when we took the car out for a drive it went perfect but under hard acelleration it just dies…
i have done everything i can think of even put in clear fuel lines running from the fuel sender through the bulkhead to the fuel pump and for the return to see what is happening with the fuel and when driving normally the fuel flows freely no problem, howeber when you put your foot down all the car seems to do is draw air through the lines causing the engine to die due to lack of fuel?
i am all out of ideas on this as to where the air is coming from and the tank has been taken out and cleaned due to the fuel neck rotting and the tank is now full to the brim with petrol so the pickup should be just getting fuel in theory, but im tottaly lost now.. and any help would be greatly appreciated
thanks
Kris
Fuel tank - fuel lines - small inline filter - carburettor.
weve replaced the in line filter about 3 times so far cause of the rubbish in the tank but since it was cleared out its all been fine and clean
if so how much
diehard1974 said
do you still have the pierberg
if so how much
you have pm
