Check valve on the vacuum brake line.
Hi guys,
Is there any one on this forum, that could indicate me of were I could get a check valve that sits on the vacuum brake line. VW agents say that its dicontinued.
On ebay they have a picture of it this is the link.
http://www.ebay.co.uk/itm/VW-Rabbit-Mk1-Golf-Caddy-Brake-Booster-Vacuum-Hose-/360234240348?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D3739971957462320178%26pid%3D100033%26prg%3D1011%26rk%3D2%26sd%3D220554420106%26
Any help would be appreciated.
Thanks.
Ernesto Soares
Perhaps Crazyquiff will be able to help out http://www.golfmk1.co.uk/
which one are you after, the one with nipples on? if so its on loads of vws, mk3 golf still use them. getting it into the plastic pipe is tricky though need to put it in boiling water to soften then shove the valve in
