Campaign not starting
(In Topic #148099)
I posted a week or so ago about my Campaign cutting out and losing power/revs and then not starting again.
I think it's an electrical issue with the fuel supply as when I turn the key up to crank it over the fuel pump isn't priming as before.
I fitted a new Bosch fuel pump last night and still no joy. I have tried 2 relays, the original (with the number 2 on top) and a second I have (probably from an old MK1 I owned before, with number 63 on it), but again I'm still not getting the new pump to prime.
Any advice?
Should I chuck a new relay in? or should I look further into the electrics and wiring? despite not know what I'm looking for.
Cheers.
When the car cuts out is it all of a sudden? Can you keep the revs up with your right foot or does it cut out completely?
cutting out
also
to start with, fit a relay 17 or 18 to the fuel pump relay socket, this will make the pump come on with ignition. if not, check fuse and pump wiring. if it does, try starting the car. if it fires up then its a relay, socket or wiring issue. if not, its a dizzy or wiring problem
