Cabby Fuel Filler Pipe Change
(In Topic #143715)
1991 Golf Clipper Convertable
1800 Auto
1800 Auto
the tricky part is if you have a later cabrio and you're trying to fit a tintop pipe, it needs a bit of a tweak to fit. few threads around on that but it should be pretty obvious what needs doing if you compare the new to the old. i believe crazyquiff does a direct fit neck for the later cabs, gsf does the tintop/early cab filler neck i believe
