best place to buy clipper fuel tank & filler?
(In Topic #152571)
Thinking of biting the bullet and getting a replacement tank and filler…the hesitations driving me mad and sure its the rust/crud in the tank- and whilst I'm their may as well do the filler' invade this is the cause.
Looked at gsf (£180 tank, £55 filler) and vw heritage (£110 tank, £99 filler) for the cabrio….anywhere else I should checkout?
Ross
Brad. said
I got my tank for £60 at Ecp with some discount on
£160 on there…would need a huge discount
http://www.ebay.co.uk/itm/VW-GOLF-CONVERTABLE-89-92-SCIROCCO-1977-93-PETROL-TANK-/320878487656?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D14588%26meid%3D5945206399931421189%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D220675677062%26
It cost about £100 at the time… gone up now to £165
rosslpenny said
No idea then. Give em a ring for what its worth?
rubjonny said
if the filler neck is the casue replace that first. tie some string round a magnet (so you can retrieve it) and chuck it inside the tank. clean it off every couple o days and eventually that should catch the worst of the grot. put a filter on the level sender inlet pipe, that will help catch some more of the grot
I'll ensure I give it a try tomorrow- adding the filters a good idea however where should I drop the magnet it on the string, by the sender? Also can I just drop a couple of magnets in the tank?
rubjonny said
thru the level sender hole aye, i wouldnt leave the magnets in there forever as they could start breaking down themselves. an alternative is stick magnet to the bottom of the tank on the outside that'll catch and hold the rusticles in place so you can scoop em out
Cool- I'll get on it tomorrow….now just to find a magnet….
Right, inline filter in the sender and although I've not got the magnet in yet (eBay order as couldn't get one anywhere) after a 7mile drive the hesitation is back. Is this because the filters catching the grot from the tank? If so, should I replace it each time the hesitation comes back and eventually hope it cleans it all up?
rubjonny said
yep basically keep an eye on the filter, if the tank is really bad its going to clog itself pretty often. you need to get a magnet on it at the earliest opportunity! anything will do old speakers are perfect donors for big strong magnets
waiting on blummin fleeBay….the magnet search in the meantime will continue
thanks for you help
You can use a tin top filler neck. it's much cheaper.
Hope this helps
E
dog_ron said
Hi Mate, i seem to be having the same prob as you and been given the same advice about the magnets, ive literally just bought a tank from fueltanksdirect aka ECC motor factors just paid £106.02 for tank and delivery. hope this helps
Cheers mate- got a new tank but the problem persisted…ended up with the carb off and that seems to have solved the most enoying issue.
