aux air valve
(In Topic #138877)
aux air valve
hi...gotta change my valve on a 1.6 1980 golf.as any body got any advice before i do it on saturday on the procedure or is it a straight forward job.any advice would be good
easy peasy, undo some bolts and clips, swap, done
cheers john for advice....especially the bit about bolts and clips...im no longer in the dark...cheers,eee..ill let ya know the results
im sure you would have figured it out for yourself, its one of those jobs that is more complicated to explain than it is to actually do it
well i fitted the part and to be honest the designers could not of hidden it any better if they had shooved it up their arse,,,,,,seemed to go ok but the test is cold start in the morning
