Ashley manifold?
(In Topic #93465)
Ashley manifold?
Volkswagens With Attitude
i had the same damn problem and you have to lever it across onto the studs BUT mine snapped!! i pulled off the lights and the near side wheel started spinning up over a drain cover, when it gripped again, engine tilted… SNAP!
got an exchange and they offered to heat it up and fit it to a spare head properly before handing it over… still got it and still in 1 piece!
once you've got that fitted it then take it down to an exhaust place to get the to heat up and fit the exhaust proper
ashley exhausts arent great quality, i know! back box's done fit right and need alot of work to like up then they fall apart inside out after 6 months and sound aweful! manifolds are good once sorted as the centre pipe is but will need heat to line the pipes up proper
'69 MG Midget 1275 (currently restoring, cammed and ported head) '81 Lhasa 1600 GTi - kent GS25 (294) cam, full supersprint mani back, filter, 2.2 throttle body '82 Audi 80 Sport '97 20VT Passat (AEB with a 57i) '84 Silver Campaign - DX but AEB coming
