Air intake hole sucking air?
(In Topic #123333)
jellybelly said
thats a valve where the vacum of the dizzy cap should be plugged into
So are my pipes wrong then?
jellybelly said
i might be wrong any
but on my car that is where it goes
So your car is the same as mine or the other way round?
BTW my MPG guage works fine!
when I got the car it went nowhere and the only place I could find is there!
I do have a whole hoast of running issues so I won't be too suprised if it's wrong!
All I know is I still have a hesitation/miss that just wont go away..but is not always there
Cheers for your help though
PIPES
Re: PIPES
mustang351 said
IF YOU HAVE A MPG GAUGE THEN ONE PIPE SHOULD GO THRO THE BULKHEAD TO THE DASH…THE CONNECTOR ON THE T PIECE NEAR TO YOUR DIZZY IS SOMETHING TO DO WITH THE MPG GAUGE AND GEAR SHIFT LIGHT..
are you sure? my mpg guage is not connected to the dizzy, its connected to a t-piece near the inlet manifold.
cedar said
As far as I know the vacuum for the distributor should go to the back of the throttle valve, the hole you've got that was taped up should be a spout with a blank on it, it's been broken off. Just put some 'Leakfix' in it, the car won't run properly with that hole there.
Many thanks - spent a good hour or so searching the forum and finally found some pics but still alot of research and work to be done!
