Air flow meter upgrade?
(In Topic #135581)
Has anyone any practical experience with going fro 60mm to 80mm?
Advert below and this is what they claim/suggest:
"Porsche 924 CIS 80MM Air Flow Meter, MK1 VW Upgrade
Part Numbers(S): 0 438 120 103, 047 133 535 E
This is the largest intake diameter CIS air flow meter you can get, 80mm!!! Direct bolt-on upgrade for MK1 Rabbit GTI, Cabriolet, Jetta, Scirocco. A significant improvement over the small factory 60mm. Increase in main intake size will maximize the output on tuned motors with common performance modifications such as; cams, big bore throttle body, fuel enrichment kit, etc."
http://cgi.ebay.com/ebaymotors/VW-Porsche-924-CIS-80MM-Air-Flow-Meter-MK1-Upgrade-_W0QQcmdZViewItemQQhashZitem4aab03376bQQitemZ320696694635QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
MK1 Golf Gti - Mars Red Campaign / MK2 Golf Rallye SE/ MK2 Golf Gti - Black 16v (small bumper) / Corrado - Red G60 / Porsche 911 (Daily)
The airflow meter isn't a restriction. So….not really worth it.
16v one is common and a bit bigger than the 8v, but as above it probably wont make any difference
