A tricky one...
(In Topic #118382)
A tricky one...
Got a 1990 H reg Mk1 GTI Convertible. Cold start valve was off when I got it as it apparently caused running problems. Recently tried to fix it and encountered a few problems. Had it tuned yesterday with the cold start valve on and after a juddery start where it needs throttle, it ran 'perfectly' and all CO2 and emissions are fine. A couple of weeks ago I bought a new thermotime switch as it was tested externally and didn't shut off when engine temperature should have disabled it, but it is still showing the symptoms of constant over-enrichment. Also tested fuel pressure - all fine. When driving normally, then coasting, then back on the throttle, it judders and then seems ok but in genral I would say it feels laboured, like it is running too rich/lean.
Starts and runs fine with the cold start valve disconnected but I want to get it running as it should be.
Any suggestions would be greatly appreciated. The car has not been 100% since day one of me owning it and it's a shame.
Cheers anyone.
Life Member
cheers.
injector test
next step will be to clean up the WUR. any other ideas?
done?
