a hole in my exhaust...help!
(In Topic #112888)
1. Buy the exhaust yourself and try fit it. Its a bit of a pain, what with seized connections and being under the car, and also the route it takes means that when the clamps are not tight, it doesn't sit properly, sags, and this will lead to it knocking on the rear axle. You need to raise the car quite high to swing the exhaust under the car and around the axles, etc.
2. Go to a local exhaust/fast fit place (avoid Kwik Fit, I've head a lot of bad things about them) and they'll probably do it for cheaper than you sourced the exhaust!
