8v gti problem
(In Topic #142929)
8v gti problem
Many thanks for reading,Darren.
1983 mk1 golf gti campaign
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
back to the issue in hand… has the car only just started doing this? do you know when the last time this was serviced ie plugs, leads, air filter etc?
it could be a number of things but to me it sounds like its running a bit rich which is why its rough at idle… have you checked the plugs to see what colour they are? if they're black and sooty you'll be running a wee bit rich, if they're white then its lean… if you have a haynes manual it will have some pics describing this.
where abouts are you located mate?
Matt
'69 MG Midget 1275 (currently restoring, cammed and ported head) '81 Lhasa 1600 GTi - kent GS25 (294) cam, full supersprint mani back, filter, 2.2 throttle body '82 Audi 80 Sport '97 20VT Passat (AEB with a 57i) '84 Silver Campaign - DX but AEB coming
mine went on the way to Bournemouth, 15 mile into a 160 mile round trip and driving through Boscombe high street reving the nuts off to keep her running wasnt too amusing! was ok cold but once warm and the pcb expands is when the fun began lol
I'm in Guernsey Channel Islads Mate.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
check your rotar arm and dizzy cap to see if there's any build up or wear… after that it may be worth getting your CO checked down an mot station. I know its passed the last one but they do tend to be quite soft on the older classics (sympathy!) other than that i'd check the injectors and system pressure…
generally, if the fuel pump fails it will just stop working… if its got a bit of dirt in it or its failing it will usually start under fueling which you'll notice higher in the revs which is fuel starvation… your probablem sounds like the opposite.
if its none of the above then i'd possibly look at timing (check your vacuum advance pipe as some people lose these and adjust the timing to compensate), then maybe check the cam timing is correct… do you know if you have an after market cam in there of is it standard?
