16v fuelling set up
(In Topic #120310)
16v fuelling set up
Hi guys, can anybody start me off by pointing me in the right direction with regards to sorting the fuel system out on my 16v conversion. I'm starting from scratch because I want to do it right, so any ideas on how I should go about tackling it, bearing in mind that my car was a driver origionally and had a carb. I've got a gti fuel pump and accumulater but not sure where to mount them. Also the wiring is becoming a worry, but I'm up for the challenge! I'd prefer to use the injection on the kr rather than switch to carbs. Regards kris
all the studs you need for pump and accumulator are under there, just need to make sure you have all the brackets!
HI!Good photos,could you make a general photo to see the location of the fuel pump and the accumulator?
Thanks!!
Thanks!!
the fuel pump is next to the fuel tank, the accumulator is a bit further back. once you actually go outside and look at your car you'll see
see the 1st photo, in the background you can see the filler neck, 3rd photo you can see the side of the fuel tank, and the rear beam mounting bracket.
