16v fuel pump replacement
(In Topic #107131)
Went to re-furb my mk2 1.8 16v KR fuel pump for my caddy earlier and on closer inspection the thing is rotted through!
Im in desperate need of a pump as the caddy goes into the garage on friday!
Whats the best replacement pump other than another 2nd hand replacement?
Id rather buy a new replacement aftermarket one
But i have no idea what pressure it should run at? etc etc
Ive seen facet ones like this -
http://cgi.ebay.co.uk/…A12%7C39%3A1%7C240%3A1318
which run 4.5-7 psi
and ones like this -
which run 7-8 psi?
Will one like that work just like that, or do I need an accumulator etc??
As you can probably tell its not one of my strongest subjects haha
Any other 16v people out there running a non standard set up?
Cheers for any help guys
Mk1 caddy 16v
The caddy tank is gravity fed as the outlets are at the very bottom of the tank, of the people I know who have done 16v conversions theyve had no problems with fuel starvation on the standard pump.
So if I have to used a standard pump, is there any other pumps that will be match off other vag cars? Any mk3's etc
Mk1 caddy 16v
