'C' shape exhaust clamps
(In Topic #94798)
Hi, can anyone tell me an easy method of re-fitting the 'C' shape clamps that join the exhaust manifold to the down pipe on a 92 clipper? i just can't get them back on!!!
I've heard you can use a standard U exhaust clamp in reverse?
Any generous exhaust fitting place will let you have one for free!
Put the nuts before the bar and loosening the nuts will push out the bar.
Hope that makes sense?
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
Thanks for a quick reply but sorry i'm not getting it?? :dontknow:
can you please explain a bit more for a thicko.
Use a standard exhaust clamp (you can get loads of different sizes)
I bent the edges on the bar so that it was straight. Then flip it over. Move the nuts to the underside of the bar - not the top as pictured and then loosen the nuts. This pushes the bar away from the end of the clamp and prises apart the c clamp.
There is a tool for it of course - See here!
http://cgi.ebay.com/eb…50204144291QQcmdZViewItem
My cheap ar5e method though is as good as free!
Does that make more sense?
1990 MX5 Mazda
Worked perfectly !
Many thanks !
Many thanks !
Pleasure!
1990 MX5 Mazda
