NOS radiator card, NOS ACC pedal repair kit, Used anti gravity valve.
(In Topic #238257)
I've found the following items. A NOS radiator card, part number is 161 121 284C. The wing nuts have surface rust and the card has bent slightly. It could probably be eased back into shape over time. The accelerator pedal repair kit, part number is 171 798 101C and is boxed and consists of 13 pieces. The anti gravity valve is used. It has the tubes still attached. Comes with the foam protector and a home made bracket. This may have come from a Mk2 Scirocco but is the same part number. 161 201 753. I'm located in Devon but happy to post, signed for delivery. Prices have now been added, see below.
Last edit: by Vic
The valve comes with the pipe work attached. For the anti gravity valve £35. Repair kit £15. Radiator card £30. All are ono. I'm happy to post at your expense. Alternatively £50 posted for everything.
Last edit: by Vic
