Yet again more electrical faults with my golf cab gti !!!!
(In Topic #147583)
Its relay pos 6 No 53. Take it out and inspect it and clean the terminals up on it to make sure you have good contact. Just because it clicks it doesn't mean it's switching over the poles.
Are you testing with the key in the ign at position 1?
The key need to in the ign and turned to pos 1 to make it work.
There is a brown wire that runs from the end of the column and onto the steering rack inside the engine bay. This can become worn, so check that for continuity.
I would start at the horn pad end and check that the contact tab the ring under the wheel is in good condition and making conatct
I have had a similar issue with my indicators and it was cured by taking the bulbs out of the holders, cleaning them up and the contacts.
I then double checked the front indicator wiring where it goes into the plugs and gave it a wiggle, all seems good for now.
I suppose it's going to be a case of tracing the wires back.
If you have an alarm or immobiliser that might be causing issues.
I'd also consider checking the binnacle connections just in case they are dirty too.
1977 Leyland Clubman
2012 BMW 3 Series Sport.
