WONT START!
(In Topic #143081)
WONT START!
Yeah, clean up earth points if you want….but it started fine when you put the 12V directly to the starter motor, so it doesn't make sense that it could start fine here, and not using the ignition switch. I reckon the problem is elsewhere, or the info isn't quite right.
the red/black wire goes from the ignition switch to the fusebox direct, then from fusebox direct to starter. no relays in between.
if an old alarm has been installed that could be the reason for everything as they're usually tapped into the indicator wires as well as the starter trigger.
as paul says the fact starter turns when you bridge it means all the live and earths to the starter are fine, the issue is on the red/black somewhere. follow the red/black back though sometimes there is a plug in the bay where the red/black wire from starter joins to the section that goes to the fusebox. might just be crud buildup here
