wiring in instrument cluster
(In Topic #74231)
The plastic clip is labled 1-12 so what colours go where?
1272 driver with a magic tree!!
The plastic clip is the conection to the printed circuit board and it pushed onto the bottem of the cluster…
Basically all i need to know is what colour wires to the number pins…
Am I missing something here or are you??? :dontknow:
I knew this woundlnt be a simple answer!
You have a rev counter? yes?…you may also have a speedo…along with a load of other gauges…this is called a intrument panel….!!
And to make this intrument panel work you push in a white clip into the bottem of it, now then…if you look at the clip closly you will know that the pins are labled 1-12 for different colour wires… what i wanna know is what colour wire goes to what number pin..
:mrgreen:
Thanks in advance low'
Life Member
Cant find the info newhere on the net eithor..
If any1 wants to take there dash apart and have a look for me, id be most greatful
For eg, on my Campaign it is a 14-pin plug. On the wiring pic (from memory) a connection would be shown as 1/14, meaning number 1 on the 14 pin plug.
I had seen a link somewhere recently to haynes manual or similar online which would have the info you need - I can't find it now - anyone know?
http://volkswagen.msk.ru/index.php?p=page09
very useful wiring diagrams and much easier to use than the haynes ones imo
Helios Blue
Like where does it tell you the colours?
This is doing my head in!
This is the link you need from Zaks link.
Open the zip file, the last file on the list (79.PDF) is the one you need. scroll to page 5. The right hand side is your instrument cluster with the "Multiconnector" and it's numbered pins at the bottom.
Very handy - I used it to sort my warning lights etc out when I used the after market "Idiot Lights"!
My Build Thread
plus.. i plugged it in and the oil buzzer cam on..never heard it before in my car…didnt think it even wored! then a strong burning smell and i saw a little smoke so turned off ignition striaght away and un pluged it….
Do you think i've fckud my clocks up? Would of been easy'er getting an auto electrition out and paying ?100 to sort it for me…
