wipers wont turn off!
(In Topic #79082)
got in the car tonight after work and it had been raining, turned wipers on but they wont turn off now when the engine is running!
is it run from a relay in the fuse box area? if so which one is it so i can check it.
any ideas what it could be?
Hi Optimusprimer
Looks like it could be the self park switch in the motor . You no when you operate the intermittant wipe the wipers do one clean sweep then turn them selves off and go to the bottom of the screen ? Well if this fails they will stay on . The motor is supplied with a permanant live for this facility + it allows the wipers to self park at the base of the windsceen .
You may need to strip and clean the motor and the gear assembly . If its faulty a MK2 will provide a good replacement [search the forum for how] Furbers at Heapham has 2 in stock
Cheers Chudd………….
Cheers Chudd………….
or the relay full of water!! u did say it rained??
Regards Volkswarren
Is it just the wipers or does the washer run too? Lights on or off? I had that a while ago, when the sidelights were on, and the fault disappeared when the fusebox was lifted out. There was a short between the wires behind the fusebox, which has now vanished (permanently, I hope!)
Big
Big
checked relay, full of water! not impressed! shook said water out, works like a charm again.
thats one bit fixed but leads to the bigger question of where is the leak?? turns out the front window rubber wasnt sat right! job done, thanks all
