wipers wont turn off!
got in the car tonight after work and it had been raining, turned wipers on but they wont turn off now when the engine is running!
is it run from a relay in the fuse box area? if so which one is it so i can check it.
any ideas what it could be?
Hi Optimusprimer
Looks like it could be the self park switch in the motor . You no when you operate the intermittant wipe the wipers do one clean sweep then turn them selves off and go to the bottom of the screen ? Well if this fails they will stay on . The motor is supplied with a permanant live for this facility + it allows the wipers to self park at the base of the windsceen .
You may need to strip and clean the motor and the gear assembly . If its faulty a MK2 will provide a good replacement [search the forum for how] Furbers at Heapham has 2 in stock  :D
Cheers Chudd………….
or the relay full of water!! u did say it rained??
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
Is it just the wipers or does the washer run too?  Lights on or off?  I had that a while ago, when the sidelights were on, and the fault disappeared when the fusebox was lifted out.  There was a short between the wires behind the fusebox, which has now vanished (permanently, I hope!)
Big
checked relay, full of water! not impressed! shook said water out, works like a charm again.
thats one bit fixed but leads to the bigger question of where is the leak?? turns out the front window rubber wasnt sat right! job done, thanks all  :D
