Wiper stalk???
(In Topic #117323)
Wiper stalk???
Volkswagens With Attitude
means you can swap all non-gti stalks about and all gti stalks about too.
Jon.
Badvwboy if you're wanting to have a look at the base of the switch, this might help. The end of the wiper lever forces itself passed 3 plastic ridges when you push it into the positions. It sounds like yours is being blocked by something so I would have a look inside. You just need to take off the steering wheel, unscrew 2 screws on the underside of the steering column to remove the lower plastic cover, pull out the two big multi pin connectors from underneath, unscrew the 3 screws on the top that hold on the assemblies and gently pull off the indicator switch section, take into account that the indicator lever holds onto the full beam switch with a lug near its base, this needs to go back how it was when you reassemble. Then all is revealed for the wiper lever. The area that has the ridges for the 3 switch positions is on the left, the white plastic blocker on cars without intermittent wipe is at the top left and pops out. You must have intermittent wipe though, so you shouldn't have one of these blockers. With any luck you'll see why your lever won't push passed the lower 2 ridges for the other two positions?
